Steering dampers
May 6, 2016
4
3
E.Moline,Ill USA
Considering a steering damper for my FLH / Motortrike conversion. Lots of choices out there. Harley uses Ohlin brand on their Tri Glides. I have priced them through the local Harley dealer and also on-line. Very expensive either way. $450 - $ 700.
Are they worth it? Is the Ohlin unit that much better than $150 - $200 ones i have seen on-line? Any thoughts?!
Ohlins or Drag seem to be the best , in my opinion. Good stuff ain’t cheep.
BTW :welcome:
Well, as I wrote elsewhere, the Ohlins damper went 134,000 miles before the female threaded rod/bearing broke on end of damper. Ordered direct from them for replacement parts for $46. Damper works like new again.
Oh, and welcome to TT with greetings from Long Island.
I bought a daytona brand offf e bay, total waste of $159
bought a $20 dollar deal at swap meet, mucho better
still thinkn on putting a vw stablizer off older car on, still have head shake at low speed.
$ 30 bucks up on ebay, vw for the money, outlaw i know runs them, likes them, i may also, someday. ;)
1 nice thing about the OEM Ohlin unit is that Ohlin will rebuild it. Try to find 1 off of E-bay, like from a wreck or salvage & have them rebuild it or do it yourself if your so inclined. It's just a cylinder.
Not avialible
Damper from bk rider is not avialible and they dont know if they will get it back in stock. problem with supplier communication they said.
There are two schools of thought for the relevance of the shield (deflector).
One is that it keeps the engine cooler ???
Two is that it re-directs turbulent air away from the rider ???:Shrug:
Many have been removed and never re-installed.:Shrug:
Not avialible
Now I notice the one from BK biker is not available and it did look like it would fit any hints and universal ones along with brackets
do you have a low speed wobble around 30mph?
didnt see it any of the comments.. may have missed it
just making a guess here ...
do you still have the stock triple tree?
is so get a set off raked trees
i should away with most of the wobble and you will think you added power steering
Little bit of wobble
Yes slightly new rear tires helped out a lot. Also set the tour pack back as far as it could go. Puts the passenger back further and puts my weight back a little bit further as well that helped out a lot . Got a new trach specific Avon front tire coming hopefully that will make it even better yet. But yes about 30 miles an hour when I’m just moving along if I accelerate no problem just usually when slowing down or just cruising about 30 miles an hour what would pressure would you recommend running the new Avon tire Would lower pressure be better for wobble or higher pressure
Also don’t wanna spend the money on the triple tree trying to keep it as economical as possible
ah understand
that wobble at about 30 seems to be the nature of some beasts... with 3 wheels rather trike or sidecar... no explanation why that is....
i dont believe the rear psi will make much difference...at least not on any that ive build
a little lower in the front might... but if i remember .. low enough to help.. the tire is way lo an would over heat..the front
i have had one sidecar and one trike i couldnt get rid of the wobble no matter what i did .. and gave up... got the best of me (i hate that)
this is what i used...
https://www.jbugs.com
seach pn 113425021 or 113425021J
there are several version i find these work well
certainly more place even an auto supply would have them i ask for one for a super beetle 71-74 i just did a google searh to find u a photo
you need a heim joint 3/8 i think for one end
it should be as close to 90 degrees from the stem so it doent wear out the rubber bushing..
and it can be quit a pain to get it in the right spot so you are using the full travel of the damper
this was the side care obviously not a sliding front end but still a pain to get in the right place
if you can afford it at some point go with the trees you will wish u did it sooner... steering is so easy
ah understand
Yes I looked into a triple tree in the past and thought about doing it, but then I read that you have to change the ignition switch? Because it might interfere with the tank. So I have made a big improvement over when I got it getting the new trike tire mounted Wednesday and it’s in the Avon trike specific tire hoping that will help. I did play around with air in the back tires. The tires it came with were 235 wide put 215‘s on their road a lot better steer it a lot easier. But I notice if I play with the front fork pressure rear airbag pressure rear tire pressure and front tire pressure changes the speed at which the wobbling starts. I didn’t know if there was an ideal setting for each? But I currently am running 24 in the rear tires 42 in the front tire which is a front motorcycle tire, 10 pounds in the front forks and between 50 and 70 pounds in the rear as I am fairly Large About 450 pounds combined weight thanks for your help
Bullet Proof
