Steering dampers
Yes I looked into a triple tree in the past and thought about doing it, but then I read that you have to change the ignition switch? Because it might interfere with the tank. So I have made a big improvement over when I got it getting the new trike tire mounted Wednesday and it’s in the Avon trike specific tire hoping that will help. I did play around with air in the back tires. The tires it came with were 235 wide put 215‘s on their road a lot better steer it a lot easier. But I notice if I play with the front fork pressure rear airbag pressure rear tire pressure and front tire pressure changes the speed at which the wobbling starts. I didn’t know if there was an ideal setting for each? But I currently am running 24 in the rear tires 42 in the front tire which is a front motorcycle tire, 10 pounds in the front forks and between 50 and 70 pounds in the rear as I am fairly Large About 450 pounds combined weight thanks for your help
id keep experimenting.. can always go back
interesting to see how that trike specific tire works
might look into other brand of trees seems there should be some made without moding the switch
papa zook could probably help you
wobble cured
ah understand
that wobble at about 30 seems to be the nature of some beasts... with 3 wheels rather trike or sidecar... no explanation why that is....
i dont believe the rear psi will make much difference...at least not on any that ive build
a little lower in the front might... but if i remember .. low enough to help.. the tire is way lo an would over heat..the front
i have had one sidecar and one trike i couldnt get rid of the wobble no matter what i did .. and gave up... got the best of me (i hate that)
this is what i used...
https://www.jbugs.com
seach pn 113425021 or 113425021J
there are several version i find these work well
certainly more place even an auto supply would have them i ask for one for a super beetle 71-74 i just did a google searh to find u a photo
you need a heim joint 3/8 i think for one end
it should be as close to 90 degrees from the stem so it doent wear out the rubber bushing..
and it can be quit a pain to get it in the right spot so you are using the full travel of the damper
this was the side care obviously not a sliding front end but still a pain to get in the right place
if you can afford it at some point go with the trees you will wish u did it sooner... steering is so easy
New Avon Bias Ply Trike Tire did the trick. I can now take my hand off the bars at any speed and no death wobble
Marks2024
