Handlebar Grip Options
Jul 1, 2016
34
29
Macedonia, Ohio, USA
Nancy rides a 2017 Tri Glide, & would like to try a set of grips that would be smaller in diameter than stock. The stock grips are 1-1/2" in diameter.
Has anyone installed a smaller set of grips they would recommend? I've found 1 or 2 that are advertised as smaller in size than stock, but (in general) actual sizes are not given.
Thanks!
Thanks!
not sure check Avon memory foam grips they come in three sizes. Avon has a wide assortment of great grips down to one Inch check them out I love my memory foam but they only go down to 1.3something.These are 1.6DSC00566.JPGDSC00570.JPGDSC00571.JPG
Thanks Fearless - we did see the Avon Memory Foam grips & the Ø1.375" are a possibility. I didn't see anything as small as Ø1.0" though. If you've seen something that small - or smaller then the small Avon Memory Foam grips - I'd welcome a link!
Hi Kevin. The HD bars are 1". The grips would have to be bigger than that. You might be able to find handle bars that are smaller than 1" though.
Jp cycles check the Avon selection
Not much wiggle room with the throttle by wire grips IMO
No, we aren't going to different bars - the trike had Harley's Reach Bars installed before we took delivery & that set up is good for her. We are just shopping for smaller diameter grips.
Bullet Proof
