Handlebar Question
Bouncer
50+ Posts
May 16, 2021
56
58
Milwaukee, Wi, USA
I'm changing my handlebars.
Can anyone tell me from experience what height bar I can install on my 2017 tri glide without having to replace the brake and clutch lines.
I want to be able to adjust the bars in any position I like, not limited to straight up next to the fairing because pulling them back makes the lines look like stretched rubber bands. That's not my idea of a good fit even though they will fit.
Thanks, Jeff
Thanks, Jeff
I put 2+2 Sweeps on my 2020 Tri. Didn't have to replace the cables but I won't be able to go any higher without replacing.
Thanks,
Does anyone have a part number for the 2+2 widesweepers that fit the 2017 trike?
There seems to be several variations of the same name bars.
Thanks,
I don't have the 2+2 bars but do know there is a wide version and a narrow bar versions, that is what I know, maybe somebody will chime in, I do know that the people that have them like them and it is about half and half if they have wide or narrow, personal preference
All for now Trampas
Most use the narrow 2 + 2 sweeps
Narrow Part number 300518
Wide Part number 300516
Thanks, and I see the difference now.
Both bars are the same width
I thought that was the difference between them but it's not.
The narrow is 29.7 deg hand position
The wide is 39.0 deg hand position
I never liked the old school wheelbarrow style handlebars back in the day.
I preferer a wider hand position.
  • Like
Reactions: GTK
I did the 300813 bars on my 2017 Triglide. Wide 2+2 sweepers in black. The only issue I had with them was the holes for the wires were very small and I had to ‘relieve’ them a little. The black powder coat is well done and perfect for my black bike. You might consider replacing the rubber bushings with poly ones while you are in there.
Finally, a definitive comparison between the wide and narrow bars
Those are the 27.9 deg which makes them the wide sweeper.
Thanks for the info.
I put KST Kustoms 12" Mayhem Baggers with no need for extensions on my lines. I have a 2015 with Hyd clutch. Not sure about a cable clutch. I love the bars.
Kurt
Just put the 2+2 narrow sweepers on my 2020 Tri Glide. No cables needed, and they make ALL the difference.Love them, a much more comfortable position and way easier to steer the bike.
JStogner
