Tech Tech Tech, or...So you want to build a trike?
If you do not have a place for the bypass line to connect......it does not HAVE to go to the tank. It can loop back to the low side of the pump.
Works perfectly fine but does run a chance of heating up a pocket of gas if demand is real low and is bypassing right back into the pump a large amount. Potential vaper lock.
An internally regulated pump does the same loop back to low side just all inside the body of the pump instead of 2 separate pieces.
In addition.....
That first example the bypass line could also go to the low side of the pump like example 3 does.
what is the best transaxle to put in a vw trike
Ok.....so that is a very subjective question.
The answer to that would depend on what you expect to happen.
Do you like to sport around town, bang out the gears and do wheelies?
Or
Cruise down the highway?
Two very different transmissions there.
I have my preferences. So I would want a late model single side cover irs. Preferably from a ghia.
IDon.....
I did get your pm.
But I am going to answer here in open forum.
I am not a professional trike builder. This is my....well....our hobby....our fun time. This is about sharing experiences and lessons learned.
Please post up your build.
Ok. Ask yourself some questions.
Body?
No body?
Vw body?
Highway?
Sport about?
Money? (Vw ain't as cheap anymore)
Skills?
Resources?
A vw back half. Commonly known as a beach bas***d.
Engine enclosed from the elements. Shelter from the sun. Full width rear seat. Big rides good. All the rules of a beetle, full fan and tins, cooler, air ducting ect. And wind drag. Big takes more hp to highway.
A fiberglass body or "styers style"
The open engine gets lots of free air. Cooling becomes a lot less of an issue. Lighter weight. More wheelie prone. Still full width and with some adjustments rides well (comfort wise).
No body.
Free to change width and length when you build it. Style it any way you wish.
Reversed power train.
Can use a lot of mid engine dune buggy parts. Many many parts can not be bought, you must make them. Makes a fun sports car/bike ride. Not the most comfortable riding. Short stiff, pitch. Not well suited for long distance highway or pulling a trailer. But is more motorcycle looking.
Now as we typically are building our own frames to no standard production dimensions the front end will have to be custom to it to be totally correct. Even though it may be possible to get there with carefully researched and fitted bought parts. Especially if you use all aftermarked harley parts as there is a large aftermarket for them.
By a large amount the most common front suspension for a hand built trike is a hand built leading link. It also is one of the easiest to build in a hobby shop in the garage.
Do you know how stable this ride was ? I have searched for link arm distance, most short, and this one is much longer than 6". Rough est. is that I will have near 10 inch long trail from the fork tube pivot point, minus the 5 1/2" pivot distance on the monster link arms, leaves 4 1/2 inch's, but under load I will lose about 1/2 to 1 inch in trail, making it more near 5 to 5 1/2inch's of trail when I increase to a 18" front rim. If I do the rim increase than the rear and front axle height will be the same. If I only want to have near 2 inch's of trail, well than I need to extend the distance between the fork pivot point and the axle point. Does this effect how stable the front suspension is ????
Is there a need for a drop pivot design of the fork tube point with a leading link design ?
I read that there is more stableness and control of the front end with a drop pivot, weight of trike below axle level, less when both points are level, and it gets worse when fork tube pivot point is above the axle pivot point. :xzqxz:
Excuse me, did not mean to waste anyone's time, followed link on page 3, got some answers, still trying to read some links from it.
Typically leading links are ok being longer than a springer rocker......because they are connected around the back of the wheel.
I would not advise long individual rockers.
My front end has less than an inch of trail. The lower you can get that pivot then the less trail you have to have.
If you go with a flat or level pivot to axle then stay in the 2 to 3 inch range.
And another link.
http://www.chopperhandbook.com/rockers.htm
Yes.
The Chopper Underground
Web site is basically gone. There is a tapatalk page but only a few folks and none of the old content.
Well it has been a while....
Whatcha wanna talk about now?
I have not thought of another hard hitting topic lately.
Oh yes, this is a good one. I had looked at mine and it seems the extension bar is just 1" rebar bent into position and welded in place at each end. It will be nice to see how else it could or should be done.
Thank you Rex.
Let's explain what you are doing when you shift gears.
This is an example of the "hockey stock".
The end of this is what is sticking out of the trans.
This what the hockey stick engages in the trans.
These hooks are the shift rods into the fork and synchro. You are pulling these hooks in and out individually.
Here the hockey stick in the hooks.
The trickiest trick to it all is getting that rod to rotate the right amount and stop rotating it the right place to line up with the hook inside.
The number one thing stopping the linkage rod from being rotated enough is this bushing.
It must be there and reasonably snug to the shaft.
So if you are using a stock vw shifter or an aftermarket one that is meant to bolt down to the stock location it will look a lot like this.
The mount will either be hacked out of the vw tunnel or will be a replacement stock style.
The main difference in a trike and the car is that that shift rod has been cut in two, shortened, and welded back together......and not particularly in correct or original rotational reference.
If you use/have a stock type shifter mount is is imperative that the rod goes square into the mount and centers up under the shifter.
You will be forever unhappy with the shifting and/or adjustment if that rod is not square.
That also means that the shifter can only swing some from the rear joint. Bit if you use a buggy universal joint style coupler at the trans you can swing it further.
Bending a lot of offset or welding in a bar that has a big zig zag offset can only somewhat work. It will have to move much farther side to side to get the rotation at the trans. It will also make the reverse lockout hard to set up, as typically it is the travel stop for the side to side or neutral gate.
If you need a lot of offset then the next level up is a buggy shifter box that is self supported.
With this you would do away with the original car shift rod all together.
You could use a universal joint coupler at both ends and offset it. The whole set up will be buggy parts with no instructions. You will have to work out the rotation timing adjustment.
I do not know what a chevette has, but some fwd cars do have cable shifters.
There are at least 2 types of cable shifters for the vw trans. They are expensive and are used mostly on mid engine dune buggies.
PBS shifter that replaces the nose cone.
And the Mendeola that attaches to the vw nose cone.
They are quite expensive.... if I remember correctly around 600 bucks. Rarely see them other than mid engine buggies.
Cool thing is that the shifter can be mounted anywhere and any direction you want.
Ok back on topic.
That self supporting buggy box above is for a stock type bolt down shifter. A shifter of the sort that would go into a car and bolt to the stock location.
Many of them use the stock reverse lock out plate. Then some have their own built into the handle lock out.
Then comes the buggy super shifter. It works just like that buggy base, but has it's own shift lever and a reverse lock out built in the base. It is a real good universal shifter at a reasonable cost
Thanks for this Thread ……. I'll be watching and planning My Build …. May Have to Abandon the Hobby Shop to Build Her but A Man Has to Do what He Has to Do ….. Too much great info Here I will have to peruse it better …..
Beefing up your rear brakes on a VW based trike.
If you are using a swing axle trans. (Up to 67) First you must replace the swing axle backing plates with 68 or later ones, so you can install the 57-on 22mm front wheel cylinder or the Super Beetle front 23.8mm.
Depending on year and model of your backing plates you MIGHT have to slot/enlarge the mounting bolt hole for the wheel cylinder. I have used a chain saw file from the hardware store to do this.
Also most front brake wheel cylinders that are installed on the rear are upside down. As in the bleeder nipple is on the low side and the brake line above. It can make it difficult to bleed, but it works.
On the rear of a IRS trans just install the bigger front wheel cylinders and slot the hole as needed. An advantage of the 68-on IRS rear brakes is that the brake shoes are about 1 5/8" wide compared to the 1 3/16" wide shoes used on the swing axle set up.
You also want to get upgraded brake shoes. Something semi metallic and good quality.
Along the lines of aircooled.net's "super stoppers". You used to be able to get the better shoes at your local parts store. But lots of this outdated stuff is getting harder to find.
One step better then the std. IRS rear brakes would be installing the Type-3 rear brakes (65 & earlier for 5-lug drums) Type-3 linings are wider ( 1-3/4") and the drums are larger in diameter and they already have the 22mm cylinders. Or you can use the 23.8mm front super beetle wheel cylinders with the T3 rear brakes. You will have to remove about .550" off the outside snout of the drum to use them with the swing axle short spline transmission. If you get the complete set up, backing plate, drums and all, it's an easy bolt on installation. 5-lug axle splines are 1 7/8" & 4-lug axle splines are 2 1/2" long Now there are other set ups that can be made to work, like some type-2 "Bus" and 181 "Thing" brakes, but they are hard to find and the price can be high.
Because disc brake kits have steadily gone down in price they would probably be cheaper than the Bus or Thing brakes. And disc brakes on the rear is by far the best brake set up as far as fade and upkeep.
To get better pedal you might want to install a 2-psi residual pressure valve in the disc brake line. Or a 10 psi if using drum brakes. Install the residual valve as close to the master cylinder as possible if it does not screw directly into the master cylinder. If your Master cylinder is lower than the brake calipers then you will need the residual pressure valve for sure.
Master cylinders work just the opposite as wheel cylinders. As the MC diameter gets smaller less pedal pressure is required but the longer the movement. The larger the master cylinder bore, the more pedal pressure, (but less throw), is required for the same braking.
The most common master cylinder used is the aftermarket 3/4 inch (19mm). If every thing is set up correct, there is plenty of fluid to do the job. But if the rotors are not true or the drum brakes are out of adjustment you might be lacking on the amount of fluid the 19mm bore master cylinder will push. The buggy 22mm master is very common but may require more pedal pressure than desired.
There are other master cylinders offered with bore diameters, 5/8" to 1", that you can use to adjust pedal throw and/or pressure.
Make sure the pedal comes all the way back after every time the brakes are applied. The brake rod must have a small amount of free play when the pedal is all the way back.
Make sure your pedal ratio is somewhere around 7 to 1. Pivot point to foot vs pivot to cylinder. You must have this mechanical advantage as it dramatically effects pedal pressure needed.
Use Dot-3 fluid and flush the system every two years. Hot & cold, sun and shade and part time use has a tendency to produce moisture in the brake lines much faster than if the lines are under a daily use car. Flush the brake lines with brake fluid, dry air or alcohol. One drop of oil in the fluid will contaminate the fluid.
Never get oil on the linings and forget the "brake clean" as it just dissolves the oil and lets it go deeper into the lining. Race mechanics won't let you touch the lining as even the oil off your hands is not wanted.
