Got the coolant leaked stopped. Now, just as I was pulling into the garage, it sputtered, spit, died and although it will turn over it will not start. Thinking fuel or ignition. Ideas? And I wanted to take it out on a ride this weekend!!
When ever i have an engine that cranks but won't start, I use the caveman way of seeing if its a fuel [lack of] problem i give it a shot of starting fluid in the throttle /carb intake if it kicks over then its a fuel problem...
Gary, get 1 of these, about 10.00 You just lay it on the end of the plug wire, if you have ignition it will light up.
This way you can rule out the ignition. This is made by Lisle tools, Sears and many Auto stores carry it.
Have you tried the bump cutoff button under the seat by the fuse block? (Not sure if that is the correct name.) It has a red cap on it. I have had it pop out on me. Just push it down and see if it resets. Rick
rocket1if and tomg were right! Finally got a minute to check the button. It was out. Reset and the unit started right up. Thanks guys.
Showing code P1299. Also, seems the shifter lockout isn't working, have to manually push the button in to shift out of park.
Well, since I can't PM Trike Tech, I'll just put it here and maybe someone has the answer. Coolant problem repaired, check engine light reset. Now, the switch allowing the shifter out of park, and the radiator fan motor have quit. Fan motor will not work even if the add on switch is turned on. Hat trick.
This is in the Archives
Just a note if someone runs across the Shift lever being locked in Park issue. Until you get it fixed, just leave the lever in (N) and apply the parking brake. To get it out of Park: if you open the front hood, look at the backside of the gear selection mechanism on the inside, side of the mechanism you should see a plunger type part. Push this in while reaching around and move the lever out of Park to (R). NOTE PLEASE NOT DO THIS WITH THE ENGINE RUNNING. You will need the key in the ON position, but DO NOT START the trike, until you are on it and can have the brake applied after you have it out of (P). This will get you going and keep you going until it gets repaired. This is related to the stop light problem also, but not the same. The stop light switch does multiple funchions, light the lights and also allow the gear lever to move.
