help with my 1974 Trike, clutch too far & more
Welcome to TrikeTalk, Countrychica. Great looking trike for sure! Thanks for sharing the pictures.
Countrychica, Welcome...If you can't bend the stop back enough and adjust the cable you should be able to get the clutch pedal remade at a welding shop to bring it to where you can use it.
I am so excited with my Trike but before I can even ride it there is work to be done. The clutch is between my legs and difficult to use. The clutch is way too far from where I sit for me to drive. My question's are how to bring the clutch in and can the stick be moved? Titus my Trike pictures by beautifulin916 - Photobucket
Any suggestions will be so helpful thank you and happy riding :)[/QUOTE
I assume you are talking of moving your shifter to a more convenient postition. If so yes you can move it to just about anyplace you would like it by using a "u-joint" and a different shift rod and shifter.
