Engine Date
It is definitely a mix and match.
If it is a 61 trans he will need some tall tires for the highway.
If its a mix and match as I believe it to be then, with a trans that old it might have had a 12v engine hanging off of it at some time in its life. Hence the ground out bellhousing. I agree that it was probably a 6v engine with a 12v generator conversion for better lighting, etc. Is it a 1200 or 1300? As far as I know, the heads are the best wary to tell. I can't tell from the picture but are the intake manifold mounting flanges cast on the end of the tube or are they separate, captive flanges? Cast flanges = 1200 heads.
If it is a 1200 (40HP) engine then it will not have cam bearings as the case was the cam bearing journals on those engines. Back in the day, we had a guy that could align bore the 40HP cases for cam bearings like the 1300/1500/1600 cases. I don't know if that was common practice anywhere else. I was in Memphis back then.
I wouldn't expect much, if any longevity for the engine if it is a 1200. When you get it running be sure to attach an oil gauge to the engine and carefully monitor the oil pressure as it warms up and, after warm, the oil pressure at idle. If the cases are worn (common at this vintage) the oil pressure will drop off dramatically and dangerously at idle.
If you have good oil pressure the cases may be more valuable to the VW restorers and they might be good trading parts toward a more modern engine. Check on thesamba.com.
Yes.
66 was a big odd transition year.
First half of the year was a mix of old stuff and current year.
Second half of 66 was a mix of current year and what was coming out the next year.
I want to say his looks like a 66 to 70 single port.
I look at the mount flange at head.
The 1200 flange is level.
The 13-1600 flange is tilted at an angle.
By what I am seeing I think it is the 1300-1600 single port because the manifold flange seems to be tilted.20170603_142231.jpg
Correct me if im wrong please
as far as the tall tires, im not even sure what size the tires are. They have GR60-14, but I haven't found an exact match to current tire sizes for the them.
When I say it has been ground out it could just be tooling marks from the factory, im not really sure.
Yes that does look newer than the 1200.
Concerns over having a 1200 carb on a larger engine.
I would make sure it is not running lean.
Yes that is a normal machine tooled area.
And that is one of the spots a 12v flywheel hits.
So im looking at probably a 66 1300-1600 single port with a 1200 carb on it? also it has never had the 200m flywheel on it. Am I reading this right? I know this probably a dumb question but how can i tell if it is running lean with the smaller carb? (I am a mechanic by trade but we dont deal with many carburated engines) will i be able to get that small of a carb to be ok on that large of an engine or do i need to swap in a large carb?
If it is a 66 1300cc the carb probably is not that bad. If it is a 67 1500cc or the 68 to 70 1600cc then it is likely to be very lean. You will notice right away as it will bog with acceleration and run hot at cruise. Sorta like low pressure on fuel injection.
Im guessing the only way to find the actual size of the engine (CC) is to tear it down and measure the cylinders? or is there an easier way?
:mob: SLIPPERY SLOPE WARNING :mob:
VW engines can become bottomless money pits real quick!
Don't forget that your original project was to get the trike running and see how it ran. I'd say get the needed parts as identified so far, put it together, and ride it around some and see how it does. Don't plan any long trips! Just putt around town till you know better what you've got.
If you have a trailer that it will fit on, great. (Plan B "Breakdown" for recovery.) If not, if you have a vehicle with a trailer hitch, you can cobble up a front wheel carrier to get it home Google will help you with ideas.
If you haven't ridden a trike, ride it a while before you start sinking $$$ into it.
Just my .02
Just my .02
HAHAHAHA:laugh::laugh::laugh::laugh::laugh:
Yes the plan for now is to get it running with just the stuff that is the bare minimum, I just want to make sure i'm getting the correct parts for the engine and transmission that i have now.
Chances are I will end up saving my pennies and buy a crate engine for it and having the transmission rebuilt at some point.
Just my .02
Rookie Gator sees this reply too late in the Game ...:Joker3:
AnnettDima
