cooling system flush
Dragon
250+ Posts
Dec 28, 2010
294
82
Oly, WA
Chuck
Good morning
I opened up the radiator cover in the trunk. was held on by 3 rivets and lots of glue.
took off the radiator cap and looked inside the radiator, it was full of what looked like
stop leak. My question is has anyone had the cooling system flushed, and how did they
do it.
Thanx
Dragon
Good morning I opened up the radiator cover in the trunk. was held on by 3 rivets and lots of glue. took off the radiator cap and looked inside the radiator, it was full of what looked like stop leak. My question is has anyone had the cooling system flushed, and how did they do it. Thanx Dragon
If as you say the radiator is full of stop leak....When you do flush it you might find out why its full of stop leak...Be prepared to have the radiator repaired/replaced...:Shrug: Also check the engine oil to make sure it doesn't have a milky color...:AGGHH:<br />
And i might add some people use stop leak.. for a leaking water pump''
Good morning
do it.
Thanx
Dragon
what year is your stallion , if its one of the earlier ones it should have drain hose on the left bottom of the radiator pluged off
Thanx
I guess I was hoping someone had actually power flushed the system,
rather than put a cleaner in the system and then just drain and refill.
My cooling system is fine, I just replaced all rad hoses last fall and
new fluid.
Dragon
#146
Dragon you per chance remember the part numbers for the hoses? Did you do both the engine and radiator hoses?
Good morning Gorilla
By cutting carefully I believe you can make all the hoses fit
with these 2 numbers.
O'reilly auto numbers
MBH 21441
MBH 21588
Dragon
Gray_Ninja
