2015 tri glide gearing vs. 2014 ultra limited
Jun 27, 2015
92
20
kitchener
I notice the gearing for the trike is different then my Ultra Limited. I don't understand gearing so can someone tell me what the differences mean? Does the trike run higher RPMs for the same speed?
Yes, the Freewheeler and the post '10 Tri-Glide's run higher RPM's for the same speed than the other 6 speed Touring models.
The reason for this is that they have a bit more weight, so HD geared them lower to have a bit more "felt" power in each gear, whether starting out from a stop, or cruising in any other gear.
It's not transmission gearing that is different. It's the final drive ratio done with the belt pulleys front and rear.
The new Triglides now have a 30 tooth front pulley and a 70 tooth rear pulley.
