I have posted about motor problems before and have had suggestions. I bought a sync gauge and used it today. Once again this is what I have. 2002 Roadhawk. Stock 1600 cc with dual webbers. Motor has electronic igintion. I have a stutter/ spit back as I shift from 1st to 2nd, 3rd, 4th after I go to these gears and give it a little throttle as I pick up speed. If I give it throttle grandma style it falters a little BUT if I give it a lot of throttle it goes like hell. I can be going down the road and gas it and it sets me back in the seat.
I have checked the valves ( .004 ) tried the timing from 7 to 12 degrees and this didn't help. Right now the needle valves on the right side are out about 1 3/4. The ones on the left are out almost 2. I have read several articles and some say the air bleed screw should be all the way in some say out 1 turn.
I started out this morning with all mixture screws out one and all air bleed screws all the way in with linkage unhooked. I fired it up and it ran terrible. I eventually ended up opening the mixtures screws back to about where they were and the air bleed screws up a turn or so.
I don't know what main jets are in the carbs but the low spehttps://www.lily.camera/ed jets are .045. I have read that with duals they should be .055 Does anyone know anything that can that can help.
