I have a 2011 triglide and it seems to me that every 7000 miles it needs a new front tire, I'm using the front tire now, any suggestions
well ...... everyone is entitled to an opinion ..... a rear motorcycle tire on the front of a trike will last many times longer that a regular front ... if you ride interstate maybe a front will last, but there are much more sever lateral forces working on the front of a trike ..... check it out on line .... lots of trike riders use a rear tire on the front not to mention the entire group on the Dark Side LOL here's my Dunlop I looked a long time at the tread designs .... finial decision based on that and USA manufacturer.I have a 2011 triglide and it seems to me that every 7000 miles it needs a new front tire, I'm using the front tire now, any suggestions
I have a Dunlop American Elite Rear Tire, MT90B16, part #34AE92 just waiting for my front tire to wear a little more. Rated for a heavier load, deeper tread depth and it's one of the Multi Tread which has a center wear area is a longer lasting compound. :Coffee:
I think I am definitely going to the American ELite when the tire wears out and probably run it in the correct rotation. With the Multitread it should get better mileage than the stock Dunlop.
[h=1]Just saw this Just FYII have a 2011 triglide and it seems to me that every 7000 miles it needs a new front tire, I'm using the front tire now, any suggestions
I've been reading the information on running a rear on the front for my 2012 Ultra conversion and am convinced that is the way to go. Now the issue is the limitation of options without changing the front wheel. As mine is a conversion the stock front wheel is 17", OEM tire is a 130/80 17. To keep that diameter, width and aspect ratio for a heavy bike I'm looking at these 3: 1> Michelin Pilot Activ 2> Metzeler ME Z2 3> Avon AM26. ----- I can not seem to find a rear Dunlop that will fit the specs. Open to ideas, and thanks in advance for the input.
Good deal ... it looked like the best one for the price ... I mounted mine in the correct rotation according to the arrow ... I personally don't think the tread splice comes in to play on the new tires. I looked ----A LOT---- on the net found no real reason to reverse it...... good luck with it .... mines going to the Dragon in May .....:clapping:
