I have the a major starting problem on my 05 Ultra trike with a 103 SE engine with non-stock cams and 5 speed trans. Battery new, 20K on clock. All fluids changed when I bought the trike used in June 2013. Stock mufflers.
When engine is cold, it starts OK. When the engine is hot, I start with the trans in neutral, clutch in, wait for idiot light to go off. Starter engages for a split second, then produces a God awful noise. This will continue until it just happens to start.
Yesterday, when I rode the bike home after a 30 mile ride, and put it in the garage, I turned off the engine, then immediately tried to restart, and had the same God awful noise and no-start. When I let the engine cool down for a few hours it started right up each time I tried. Ditto the next morning when I started it up.
Someone on HDforums suggested that I try a procedure of "quick start" without waiting for the idiot light to go off. I hope it will work for me.
My intuition tells me it is caused by the engine temperature, and high compression without compression release.
Has anyone had similar problesms? How was it corrected?
BTW I've read that to solve this ongoing problem, the HD stealer will fix it by installing an "SE compensator sprocket", which is now standard on the newer model engines. The hardware alone costs $250.00. I don't know about labor
This has been an ongoing problem which HD says is "NORMAL" WTH?
