2004 HD Ultra Trike Trans
Apr 2, 2011
4
3
Perkins, MI
Tony
Has any one else had the swingarm mount on the back of the 5 speed trans crack where the swingarm shaft goes through. I did, but as wondering. Harley dealer said they never had a problem. I think that the engineers tried to save 4 ounces of aluminum, the top of the casting is only 1/8" thick...looking for you comments, Tony
Tony has not happened to me but I have read of it happening before. You might want to upgrade to a 6 spd. year.
I had it happen to my 2008 Roadglide 6 Speed that I had triked. I just re-installed a whole new transmission last week.
I think my break was caused due to the swing arm shaft nut coming loose because I didnt tightened it enough when I replaced the drive belt over the winter.
A Trike rear end puts a lot of lateral stress on the swing arm and swing arm bushings. Its possible your broken transmission ear mount was caused due to the bushings being worn out to allow the side to side movement or the rear end not having the correct adjustment for alignment and proper belt tension and over time the stress cracked the ear.
I attached some pictures of what my case looked like after it had too much side to side movement
Well my 04 motor trike was line up to spec's i know there a lot of stress on the swingarm but why would the engineers even put a swingarm through a trans mount in the first place. I think its just bad engineering on Harleys part my shaft where tight. My 04 trans looks a little different.
Well i just think its was a good idea but i also think that 1450 would be a little week for the 6 speed it crossed my mind. But went bacdkt 5speed its running good for now.
has any one found a fix for this mo 06 did this last week
Kickstand_Korner
