Background first: Because of a warped brake disk, had to take off the hub which is on a spline. (Hub and disk are the same piece.) Rear calipers are on a three loop coil of steel line, rather than rubber, so had to tie them up with wire.
I went to 7 brake shops before I finely found one that could chuck up the hub in their brake lathe. Each one told me, OH yea, we can turn any disks, even AFTER I told them there were part of the hub. Anyway, the guy that finely did them had about a 3/4" arbor that he had a couple tapered pieces that slipped into the spline and could chuck the hub up tight. They let me see the set-up and the left disk was out of round probably 3/64". Turning job was kind of crappy, but they at least the disks are straight.
I had the emergency brake drum turned also. Believe it or not, it is a small (probably 6 1/2" in diameter) shoe brake that rides inside the hub, on the right side only. Though I don't use it, it had a lot of rust on it.
While apart, we put on a new set of pads (Ultimax 2 EBC DP105-OE) which Roadsmith told me were more aggressive than "standard" pads. When in fact they are what is sold by ECB as "standard" pads. With 21K miles on these pads, there were only worn about 40%. I bet these pads would go 50K miles.
Has anyone actually tried the ECB "yellowstuff" pads - P/N DP4105R. ECB tells me they are much more aggressive. One on line place has them for $82 + $12 shipping.
The pads [DP-105-OE] are NOT soft yellowdstuff as I was in the impression from Roadsmith. EBC WHOLESELLER is in Las Vegas, and I am going to try them and get the straight skinny on "yellow" pads. The correct yellow compound pads are ECB DP4105R. Next time I'll try the yellow.
I'm re-posting on this board and see where it goes.
