Wind deflector for Harley
Oct 13, 2015
48
13
Milford, MI
Bob
I was on eglidegoodies.com. There is a wind deflector that goes between the fairing & lowers. It is supposed to stop 90% of wind coming up between the fairing and lowers. Has any one tried these? They say they are adjustable. I get a lot of wind from that area. It would be nice to adjust the flow or eliminate it when it's cold out.
Just as a heads up, they seem to have several bad reviews and a C- BBB rating:Shrug:
There are several wind deflectors available on the market of the design you mention (although I've not seen any that are easily adjustable). There are also fork mounted wind deflectors.
These work very well at reducing the amount of wind hitting the rider and the passenger. They also reduce the amount of wind going across the engine.
This is fine when it's cold, but when it gets warmer, it is not good for the engine.
One thing you can do is add a Tank Lift. This reduces the amount of air coming over the top of the tank and hitting the rider in the chest. Many experience a reduction in buffeting with a Tank Lift. It will also reduce your engine temps by about 10*. This is because the air that was going over the top of the tank and hitting the rider is not going below the tank, and over the engine.
We are currently working on a wind deflector set up that will redirect air, that normally hits the rider and the passenger, to flow over the engine. Doing this benefits the rider/passenger AND helps the engine. There's a little bit about this at this link, down toward the bottom of post #86-
http://www.triketalk.com/forum/threads/30249-DK-Custom-PROJECT-TRI-GLIDE-Report-w-Lots-of-Pics/page9
Yes, I have the wind deflectors....have had them on the '09 and now '13 Tri-Glide with no issues. And, yes, it does stop the wind. Very happy customer!
I had them on my 11TG. It did help with wind come over the tank but also made for more heat around the engine due to lack of airflow. I took them off, engine runs cooler with more air. I can deal with the wind in my face.
I had the tank deflector and the fork deflectors but never used the fork deflectors. The tank wind deflector worked great from that rush of air blowing around the gas tank area. Had no issues with cooling the engine. ThumbUp
shawn.s.prescher
