Jd1a
90+ Posts
Negative, it was posted in this forum a couple years ago. It's a good idea.
Replaced the parking brake pad with the foot brake pad. Just on the spur of the moment to see if it would work. Had to tack a 3/8" nut under it to keep it straight. Now I have to order a new foot brake pad..lolView attachment 111184View attachment 111185
Trike is all serviced, catless, new rear goodyears, clutch & brake fluids replaced. Now have to wait until April for a new Avon front. 3 diff shops have confirmed April 23 before they will be available. Can't ride now anyway. Wont buy an Avon online ,as never know how old the tire is . Oh, also installed an LED lite in the trunk. Just hit the switch & man is it BRIGHT. Looks like daylight in there now.
What LED lite did you use Bill. Where did you get power?
CT CAPETRONIX 12v LED Interior Light Bar, 168LEDs 1700LM 10W, DC Amazon. Got the 4 pac ,,extras are for interior of trailer.
Pulled the coverings out of the trunk & got the wiring harness that is behind it. Wires feed license plate. Just have to turn switch to ACC. to use when stopped.,, Got some extra wire so I could route wire up & over that covering use the Tape supplied & mounted to the trunk roof onside near door. That way it lites up the entire trunk. These lites have a switch so it doesn't burn all the time bike is running. That tape is strong so make sure ya have it lined up when you put down on lite bar.
My '20 has 2 feeds. One for the license plate and one that's hot all the time which is the one I used. I wonder why the difference.
Yes there are 2 feeds (2 hot & 2 grnd) Maybe because there are 2 bulbs in the license plate..?? None are hot unless ign is ON or Acc. If they were HOT all the time,wouldn't something be ON all the time???? NO reason for a HOT lead all the time as far as I can tell
:xzqxz: I just spent hours over the past three days installing backrest hardware. The dealer installed the hardware for the backrest that I didn't have, and a new back rest, to match the would have cost just as much the hardware kit for mine. I can not believe where the battery is surgically implanted into the bike. It seems you need very small fingers and a lot of patience, which I have neither. And guess where I dropped a wrench, your right, down into the space where I could not get my fingers. Fighting to remove the battery to retrieve my wrench, I thought that this battery should have some kind on strap on to help with removal, Yea I found it under the battery. :clapping:View attachment 111367 I cant wait for spring and finally get to ride my new bike....
I love that color scheme. I want to paint mine like that. Which backrest did you get? HD has two styles. I plan on buying one very soon.
