Found a sissy bar backrest combo on eBay for $150 so it was cheap enough to try. I only want it around in case I need it. Most times I don't ride anyone, but when the time comes a passenger back rest is a must on the Freewheeler or your going to lose somebody off the back. Just didn't want to pay HD $260 + another $120 for the pad. Other than having to chase the threads on one of the body bracket holes installation went well. I did swap out the stainless steel bolts for black that I picked up at Lowes and a couple of 7/8" black plugs for the mounting bracket holes. For the few times I'll ever use it I'm satisfied with this eBay combo.
View attachment 107653 View attachment 107654 View attachment 107655
Believe me you’re gonna use it more then you think… it’s a perfect place to hang your helmet on..ThumbUp ..I use the rack on my triglides top box to lay my jacket on..If I lay it over the seat there’s a chance of the hot engine or pipe burning 🔥 it..
Gear Shift Linkage Problem
I bought the Scripted Harley gear shift linkage and installed it matching the exact length of the stock one. Took my 21 Freewheeler for a test ride and it still clunks when shifting. I did notice that there is one inch play when you move it back and forth before it goes into gear. It seems like that is a lot of free play, half inch forward and half inch backwards. It was the same for the stock setup. Does anyone have the same problem on yours? I apologize for bothering about this bit it is very frustrating.
Thanks for any help you can give.
Cap Jim
Cap Jim
Jim, the Harley transmission is a constant mesh, it is all but impossible to get all of the clunk out, you have to decide how much you can live with
Some heavier tranny fluid does help some, with hydraulic clutch bikes / trikes there is no clutch adjustment, this does not help the clunk either
Changing primary lube can help some also
I bought the Scripted Harley gear shift linkage and installed it matching the exact length of the stock one. Took my 21 Freewheeler for a test ride and it still clunks when shifting. I did notice that there is one inch play when you move it back and forth before it goes into gear. It seems like that is a lot of free play, half inch forward and half inch backwards. It was the same for the stock setup. Does anyone have the same problem on yours? I apologize for bothering about this bit it is very frustrating. Thanks for any help you can give. Cap Jim
My '21 Freewheeler has 3/8" free play. I do recall a wise man in this group say that eliminating the "clunk" in the shift will void your warranty. I say it was good enough for my '59 Pan and my '78 Shovel so it must be a feature not a flaw.
That’s right… without the clunk how would you know if you changed gears… it’s a safety issue and Harley has the clunk trademarked..😁
I will probably go to a heavier primary when I change oil again. Do you have the same amount of play with the linkage? That seems like it is too much back and forth.
Yeah not quite 1/2 inch, I have always used heim joint rods, the OEM are horrible, at least with heim joints it does not change like the flimsy stock ones
Still looking @ some bling for my Freewheeler, wondering how much longer the supply chain issues will go on:mad:
Seems like everything I want is backordered or not available, I am looking @ getting some Drag Specialties oval ( half moon nostalgic) floor boards
Still looking @ some bling for my Freewheeler, wondering how much longer the supply chain issues will go on:mad: Seems like everything I want is backordered or not available, I am looking @ getting some Drag Specialties oval ( half moon nostalgic) floor boards /QUOTE]
Those floor boards don't have the rubber cushions? Exactly what I've been looking for. Don't need the rubber anti-vibration pads on the Freewheeler there's no vibration. I may have to put myself on the notify list for those. Thanks. Apparently you can't order directly from Drag, but they list Nicks Motorcycle Salvage as a distributor and he's only about 30 minutes from me. Weather permitting I'll go check him out soon. I'll post back if your interested.
JT, those boards come both ways, D S part number 1621-0160 have the vibration dampers like our stock Shaker D shaped boards, DS part without is[h=1]w/o Vibration Inserts - 1621-0161, they also come in black pans instead of chrome[/h]
92 degrees, no wind and not a cloud in the sky. South Jersey hasn't looked this good in 8 months. Ran a real pretty 85 mile loop with a couple of stops including Steakouts on Route 40 where I met another Freewheeler. Had a good chat and found out he only lives a few miles from me and his brother is one of my customers. Had a brief stop at the Alloway Inn, I don't even know what road it's on, it's literally in the middle of nowhere. Several other bikes there. Stopped at my Vietnam Vet buddies house for a bit and took a long way home from there. I am so ready to get out of the state and do a couple of weeks on the road that I can't stand it. Soon, real soon.
I you come up to north central PA, we'll show you a good time up here on our twisty mountain roads.
Had a buddy in Breezewood PA. Was out there on my '78 Lowrider and he said "let's go for a ride, but watch the signs." Beautiful scenery. Sign ahead was a half dozen big black arrows on orange pointing left. ??? Turn, turn, keep turning, TURN SOME MORE DAMN IT! I'm scraping the pegs looking at a precipice of doom. I live in NJ about 1 foot above sea level with an impenetrable swamp in my back yard. You guys are out of your minds. Isn't it great? Love that state.
I got really interested back when we were discussing the Roadking Speedo/Tach combo on the Freewheeler, but when I factored in the shop labor to set the Anti-lock brake system up on the ECM it was pushing $700. That would have been a tough one to explain to the wife. All I really wanted was the option of having the clock up and simultaneously see what gear and RPM I was at. Broke down and spent the ridiculous amount Harley wanted for their clock. After some R&D to mount the thing where I wanted it (not on the handlebars) it works nicely. Of course time, pun intended, will tell how long it lasts. I've read mixed reviews, but there's no vibration at the mount point, it's solid and doesn't move, out of the wind and weather so I'm keeping my fingers crossed. Now I can confirm what gear I'm in and also know what time it is all at a glance. Oh, it's the little round chrome/black thing on the right side of the fairing.
Trike#1
