Voyager kit with rear ct question?
Question to anyone.
I have a 2007 Goldwing with the Voyager kit.:)
My wing has a rear car tire.
When setting the pre-load of the Voyager kit,
1. Where should the rear air pressure setting be? I set at 20 to do pre-load.
2. How much pre-load to use? 3/4in or 1in.? I use 3/4in.
3. What should the air pressure in the rear tire be? Max or less. Mine is at 37lbs.
4. What should the air pressure be on out-rigger tires? Mine are 20lbs.
Any ideas or suggestions would be appreciated. Thank you to all in advance.:confused:
Flyboy7312
