2006gold
950+ Posts
After riding through tropical depression Bill and stopping to eat I couldn't get the Stallion out of park. Anyone else had this problem?
If you raise the hood, you will see a button on the shifter, you can release it manually. When you press the brake, a switch is suppose to release it. Maybe a bad switch, check fuses, etc.After riding through tropical depression Bill and stopping to eat I couldn't get the Stallion out of park. Anyone else had this problem?
they have had a problem in the past with the brake switch and TMS has made their own switch replacement for it its now water proof which sounds like your problem , I had the same thing have a new switch to replace it with just cant get under it at this time to replace it , I solved this problem temp. using duck tape around the gear switch button, till I can replace the switch..After riding through tropical depression Bill and stopping to eat I couldn't get the Stallion out of park. Anyone else had this problem?
I've had the same problem several times. I know you can raise the hood and press the release and you can shift into drive. A couple of weeks ago I did and going down the road I noticed the cruse wasn't working and then I realized the engine started overheating. I've found that if you turn the key off and then restart the engine it will shift into gear. I have checked the switch in front of the master cylinder and I can't see what would make it work one time and then not the next. I have checked brake lights when the shifted will not shift and they work fine. It's just that little electrical gremlin that keeps getting in the way.:Shrug:
