Trunk removal
Disconnect the battery, remove seat, disconnect wiring harnesses to trunk box as well as the antenna's 2 if equiped with cb, remove 4 allen bolts inside trunk and lift off. You can also goto the honda website and look at the instruction for installing CB, but they seem a little more confusing then they need to be. Good luck.
dhinzman1
