Truckdogg4
10+ Posts
The button to the bottom trunk quit working. Any suggestions on how to fix it? I have called 3 dealers listed on CSC site and they all say they don't repair trikes.
2021
How long had it worked before it quit working? Was your trike body painted at the CSC factory or painted by the dealer? Just curious....
The problem is likely going to be the switch itself. Pull the glued-in trunk carpet down away from the switch and you'll be able to inspect the underside of the switch and wires (it's a tight space though so good luck). You may find that one or both of the two tiny wires going to the switch have frayed or pulled loose which can happen during installation. That, or the switch just failed.
Best bet is to call Will at CSC and order a replacement switch which comes prewired with the proper plug on it.
Also, after receiving the new switch, I'd suggest you first just unplug the old switch, leaving it in place and plug the new one in before uninstalling the old one and reinstalling the new one. If it works, then carefully install the new switch and ring nut as it's easy to damage the frail little wire's solder connections due to lack of space to work with.
