Trunk latch wiring
Hey all just wanted to update you on the trunk latch wiring. I located a photo of the latch with the wiring on it. The first wire is ground and second is hot and I wired the negative to the ground on the trunk light. I wired the positive to a ignition circuit so that you can only release the trunk when the key is in the ignition and turned on. I placed a push button next to the interior light above the cup holder.
Trunk latch
Hey all! Looking for information on the truck latch to make it push button open. I see the plug on the latch It has three pins. Which pin is ground and which is power? Any help is appreciated!
You probably have your issue cleared up by now, but I did wire my latch up , connected it to the inside light switch...open the trunk, turn on the light switch then off again...popped trunk popped open...
can this be done to the Venture Hannigan conversion? In-laws having trouble with their truck lock is why I ask.
wzejda
