Trunk key assembly
Oct 2, 2015
30
26
Tucson
Jack
Hi, I am a newbie Stallion owner, I bought a 2013 Blue Stallion about 2 months ago.
Today I closed the trunk took a ride and when I went to put my helmet in the trunk, the entire assembly fell inside. I managed to fish it out and open the trunk, removed the inside cover and discovered the plastic lip that the key assembly fits in had completely busted. There was just a 1/3 inch part of the lip left that keeps the assembly from falling in.
My question is has this happened to anyone else? I guess I will try to find a device with a large enough hole to put the female part on the outside of the trunk and thread the locking mechanism through it, and then screw a nut onto it to get it to hold and not fall through again.
Thanks for any feedback anyone can give me. :pepper:
Trikerjack
Trikerjack
First time I have heard of this. Contact TMS as your Stallion may still be under warranty or close enough they might send you the part (s) you need.
Tomg
Its never happened before
Contacted TMS about key mechanism problem, and they said they had never heard of it happening before.
No help
But are they taking care of the issue for you ??
Tomg
Tomg: They had never had the problem, no help offered. The key assembly is mounted in a very thin piece of plastic, where it is inserted and turned to hold it in place. The ring holding it in place is 85% broken away. Still trying to figure out a fix.
I would call them back and ask about the warranty on the trike. Next I would send an email to Jeff@motortrike.com , he is the owner of the company. They should be taking better care of their customers. It almost sounds like a retainer clip of some sort that they should have.
Tomg
Roger71!!
