Someone posted a link to a water bottle holder that attached without drilling holes in the side panels. I lost the link. Does anyone still have it?
Thanks.
D. Caliendo
Thanks.
D. Caliendo
Thanks.
D. Caliendo
It was a unit that attached to the panel between the body of the bike and the fender on the flat panel there. It attached with adhesive strips and showed a guy standing on top the the holders after there were attached to the bike. No holes to drill and seemed to be secure.
Thanks for the reply and I'll check through them.
Regards,
Richard .................
I have the suzy cup holder and it vibrates so much if you do not have a water bottle in it. Looking for a replacement now
To keep your water cold, the Butler Cup is the one to use. I have mine attached at the switch housing right side. Yep, its big but if I want a ice tea from DD, the medium DDcup will fit perfectly in the Butler, keeping the tea nice and cold. I have had ice in the Butler for a good 4-5 hours. Thicker frozen ice stays all day. They make it so it can be attached for the passenger. 20 oz cup and 32oz cup I also buy a new cup, straw and lid this year. www.glassact.com
Not sure exactly which link you may have had, but this is the water bottle holder that Kevin (DK) uses on his Trike. Hope this can be some help to you
http://www.kruzerkaddy.com/products-page/all-products/
Kelsey
It should fit with the Hyd. Clutch. I make mu own mount for the kuzzer kady. I have mine on the front brake housing. I also use a stainless cup holder I got at Walmart. When riding I do not carry hot drinks. The cup has a straw in side so I just uset the straw, will not leak or spill.
been using this for many years. Are you using the resvoior or bars. Don't care for the bar mount. If it moves to much just use a o ring between the mount.
You can still move it but it will stop it from moving when riding.
