Trike and checking your oil
Apr 9, 2017
34
64
Rockford, MI
Rob
On my bike with a warm up engine my oil was checked on the jiffy stand NOT upright. So after the trike kit it's always upright. I was not thinking when I did this.
I just changed all 3 before the kit was added. Just something to think about.
Just wondering if you checked the oil with the bike on the Kickstand [I refuse to call it a Jiffy stand]
Why would the oil be too high when you have the bike in the up right position...:Shrug:..
Jiffey stand
Mr Davidson must of been on schrooms that day . Jiffy muffin and cornbread is all i can relate it to . :cxtv:📞
I never could quite understand why they call it a 'Jiffy' stand either, my mind does wonder over to Jiffy Cornbread/Muffin Mix also. It could be an 'Iffy' if'n you don't make sure it is locked forward when the bike is parked on it. :gah:
The oil level will be higher on the dip stick if not on the sidestand. Yeah, I can't call it a jiffy stand either and I still call it a crash bar not an engine guard. I leave 1 rear wheel on my driveway to get the angle as if on a kickstand when I check oil level.
checking oil
If it was my trike I would find a bike without the trike kit and check the oil level when warm and with the correct amount of oil in it, then I would stand it straight up, see where the oil level was on the dipstick then mark that level on the trike dip stick then you would be set
Just changed the oil and filter on my 2005 FLHTC Lehman trike.
Owner's book says 4 quarts.
Factory shop manual says 3-1/2 quarts.
I put in 3-1/2 quarts, checked it hot. Comes up to within about 1/4" of the top full mark, with the dipstick oriented to drop straight down with the plug pushed all the way in.
dyno56ca
