Trailering 2022 TG
Sep 18, 2024
37
32
Tacoma,WA
Dirk
U-Haul has a 5'x9' utility trailer with ramp. Inside dimensions are 9'2" x4'9". I think the width with fenders is very close. Maybe less than one inch clearance on either side. If I remove the fenders I'l gain nearly two inches of clearance on each side. Does this make sense? How difficult is it to remove the fenders? Thanks for your input.
U-Haull has a 5'x9' utility trailer with ramp. Inside dimensions are 9'2" x4'9". I think the width with fenders is very close. Maybe less than one inch clearance on either side. If I remove the fenders I'l gain nearly two inches of clearance on each side. Does this make sense? How difficult is it to remove the fenders? Thanks for your input.
Your call - but, this does not make sense to me. With all of the money I have in my trike, I think just two inches is too close for comfort.
If I were renting, I think I might go with the 6X12 with a ramp.
Even with a 6x12, the actual width at opening when pulling on is still 4'9". I agree with @cycle7447 that it's just not enough wiggle room.
The other thing to consider is that the ramps on these U-Haul trailers are not very long and the load angle is very steep. Very good chance of scraping underside when loading unless you have a hill you can back up too or some other creative idea.
What I might suggest is to reach out to some of the trailer sales companies in your area. I have found that a few of them will rent out their trailers. It may not be as economical as a U-Haul but will work out much better in the long run. You wouldn't have to depend on removing fenders,etc... to get it to fit. Or check with family or neighbors in area that might have a flat or enclosed trailer you could borrow.
You don't mention if this is a one time deal to get your trike home or if you are planning on trip(s) and wish to just bring the trike along. If the second, start looking on various forums or even Facebook marketplace for a used trailer that will suit your needs.
Because this is a one way rental between states u-haul is the best alternative. As 7447 pointed out their 6x12 trailer should work. It nearly maxes out my towing capacity but stays within the tow vehicle limits. I don't want to own one because I don't have room to store plus I don't want to pay for license and insurance. Thanks all.
I wasn't referring to buying a trailer. The 2 links I provided although they sell trailers, they also offer rentals as an alternative to U-haul. And more trike friendly choices as well.
Like I said, the rear entry size on the 6x12 is still reduced on entry (4'9" or 57") to get onto the trailer so may not be wide enough. I would suggest stopping by a U-Haul place and measure before counting on it to work. Nothing worse than renting something only to find that it won't work.
Here is a YouTube that demonstrates the width of the entryway in a 6x12 U-Haul and pulling a quad into it. Quad is 51" wide.
He said it is a one-way rental, so unless the trailer rental has another shop where he is going, that won't work out. I wouldn't even consider using a 5 foot-wide trailer. Keep in mind the cost of a new fender or the repair costs, and as far as removing the fender, that's an option but not one I would do. Have you considered a transport company?
The 6x12 is a cargo trailer not a utility trailer and is fully enclosed. Listed opening is 5'4". I'll definitely be visiting the lot with tape measure. Inside width is 6'4". This should be adequate. Plus fully enclosed keeping the trike out of the elements.
You are going to be close height wise as well. Overall height of the stock 2022 Tri Glide is listed at 56.3" and the door opening on that cargo trailer is listed at 61". If you put a taller windshield on that, it will be real close. You will have to duck down when pulling in and will probably have to twist around to get off. There also won't be much room to get around the trike to get back out. I'm fairly certain that these cargo trailers do not have ramps. You will also need your own ramp wide enough to drive up and in or 3 separate ramps for each wheel. And they have to be able to handle the weight of your trike. That can get expensive if you don't already have them.
Also doing a 1 way rental will add considerable cost to the rental. Depending on how far you are going to travel. The $30 rental cost is only if you are dropping off back at same rental location. I checked random distances by me for one way rental and at 150 miles, rental goes up to $178. Going 400 miles and the rental cost is now $283.
I'm not trying to be a Debby Downer, I just think the U-Haul route will turn out to be more problems than you think.
PW don't worry about being a Debby downer I appreciate the advice. Going to visit local Uhaul dealer and get their input. Based on zip codes five rental runs $250-$400 depending on the unit rented. Thank you!
Big>Money
