Trailering
TonkaDriver
450+ Posts
Feb 26, 2018
490
858
Bagdad, AZ
Kurt
I am picking up a TriGlide in TX in a couple weeks and unfortunately will be trailering home instead of riding. I am looking for expertise in tying it down. What types of straps and what points to tie off from. I am already aware that it is of vital importance to not tarp it if I want the paint to survive. Please include photos if you have them.
Thanks.
Kurt
There are two hooks built into the rear frame underneath for strapping down. Put it in a cheap or expensive wheel chock, ratchet it to the chock, two more ratchets in the rear holes, set park brake, put alarm in travel mode, and you will be good to go.
My chock came from H-Freight, less than $20 I think. Trike chocks are not needed to hold the thing up so you certainly don't need an expensive one, just one to keep those handlebars straight.
We have been trailering for the past several years, last 22 months with the TG. Actually leaving this morning with it in the trailer already locked down.
Enjoy that new Trike!!!!
Thanks.
Kurt
With my Tri-Glide i put a rachet strap though the front wheel, with a rag between the wheel and rim so the strap won't leave a mark, [Careful not to hit the rotor ]
And then there's a tie down loop under each rear shock made for strapping it from there...
...Just remember to deactivate your security alarm before you start off (see your manual).....or you could run the battery down while trike is bouncing on trailer! Happened to me the first time I trailered my tri glide).....but I'm sure you already know this.
Cheers!
Thanks for the advice. I am going to check H-freight for a chock and get some new ratchet straps today.
I did quite a bit of research before setting up my enclosed trailer for hauling my tri-glide.
What I finally went with was using and EZ-Trak system. with 1 strip outside and behind each back wheel and 3 strips up front, one for the wheel chock (it is made for the trak system and enables me to move the trike forward and back to get it in the optimal position easily) and one on each side about a foot out.
To tie the bike down I found that most do not recommend tying above the suspension compressing it as that can do one of two things 1. the suspension may compress more when a bump is hit causing the ties to come loose. 2. It could also damage seals in the suspension.
I tie to the back tie down points under the rear axles and use soft ties up front around the forks just above where the fender is mounted. these points do not compress the suspension and the times I have hauled the trike it has stayed solid.
The back straps go to the rear and the front forward so they are pulling away from each other.
As others have stated put your trike in travel mode and also do not leave it in gear as this could damage your transmission.
Just my opinion and may not be worth much but it is what I do.
Bob
Bob
When I haul the trike in the toy hauler, I tie down at the same points. I have a flip up front tire chock mounted in the floor of the toy hauler, which helps with stability. Never had an issue. Jim
My mistake on getting the cheap chock from Harbor Freight. They didn't have the one that was wide enough for my TG. I ended up getting about the same thing from Tropic Trailer down in Ft. Myers.
Just a note about leaving it in gear and/or setting park brake. Since I haul mine full time in an enclosed trailer along with our car I don't monitor my tie downs at every stop. I leave mine in gear plus set the brake just in case a ratchet strap would break without me knowing it. As tight as I ratchet mine down I really don't think I am stressing my tranny.
I always leave it in Gear brake on.....When i'm trailering ....In my humble opinion in neutral the Trike will move a little [Forward and Back] and put a strain on the straps and the components that the straps are hooked to...:Shrug:
2011Spyder*
