Throttle by Wire High Idle Reset For Harleys
Jack Klarich
Guest
Oct 11, 2016
18,130
15,125
Jacksonville, FL
Jack
if your Harley throttle by wire acts up and high idles when cold starting, dont panic
Try This
To reset your idle setting back turn the ignition switch on for 10 seconds off for 10 seconds (do not start the engine), repeat a total of 4 times. That should reset your original throttle position.
The throttle by wire will remember throttle position each time the bike is shut down
That said, some are having problems rolling the throttle a bit when using the kill switch
This can cause this type of problem
There is just a bit of roll on with this set up compared to cable type throttles
The little extra roll on can = higher RPM when starting This does work, I tried it on mine when I first got it;)
Try This
I don't know about that... The M8 Is supposed to idle when Cold 1000 to 1100 hundred RPM's plus and then when it warms up...It settles down to the annoying 850/900 lope...After about a mile of riding...:Shrug:
What the above info is for if your idle is lets say high @2000, then use the method
It can and does happen withTBW
My 15 Freewheeler did the same thing twice
Your M8 only idles cold @1000 to 1100? When you cold start it?
Give or take a few hundred RPM's..Yes, Thats the function of the enricher...
Try This
Learn something new every day - exactly why I enjoy coming here.
shawn.s.prescher
