Thoroughbred Stallion
Sep 25, 2024
6
2
Idaho
Ron
Does anyone know the part number or how to find information on the 2013 Thoroughbred Stallion brake pads? There is nothing in the manual.
Are you looking for front or rear or both?
NAPA parts numbers;
front--TS7487M for a 2012 Toyota FJ Cruiser 4.0 L rear pads
rear-- TS-7976-X for a 2005 Ford Five Hundred rear pads
The statement at the end of the numbers "rear pads" means the pads were off that area of the original vehicle. The designation in front or the statement is the fitting on the Stallion.
The calipers on the front are custom made for TBMS for the Stallion. The rear calipers are from the Ford 500 but the calipers are switched when put on the Stallion. The one for the right rear off the ford 500 is used on the left side of the stallion and the switch is the same for the other side. This was so TBMS could use the E-Brake setup.
dhinzman1
