Suspension Issue
The ladder bars do not have any effect on the front wheel sitting crooked. Although the ladder bars may not be even on both sides, the front tire issue is adjustable. I have performed this many times. On your front forks, measure the diatance from the ground to the bottom of the downtubes. Are the measurements off? If the front tire is wearing on the right side, that should mean that the right side downtube is closer to the ground. Is that the case? Let me know and Ill walk you through the adjustment for it. I can also walk you through the adjustment for the ladder bars as well.
Thank You Ed and Stallion Tech. I have been reading thru every post on the forum and those (ladder bars, caliber bearings and brake light switch) seem to be the recurring theme. What about battery charging and or aux jump post. I am sure it is in here somewhere..
You can pick up a set of battery extenders from NAPA I think. They will let you add another set of battery posts used for jumping off your Stallion. I have seen most people install them in the trunk, to ease jumping of your battery.
stoney
