John Luciano
One Of The Origionals
Can u post a sketch of what you are shooting for .
hi john,Can u post a sketch of what you are shooting for .
hi skuuter,NICE......and yes, I'm betting narrower will equal better. What thickness are Your offset spacers made from...???...just curious.....Thanks.....ThumbUp
hi skuuter,
they are made from 4x1/4 inch flat stock,,, it fully boxed and was a pain in the lower extremity's,,, but in the end its a part that I don't want to fail for sure!! its heavier than the mounting built on strut so should be good to go...
I should add that it the end I will weld to strut also but probably new struts through!!
magoo
I also wondered if You were gonna' eventually weld them.....I always hate to make "suggestions" on Home Built Projects here, but since You brought it up.......yes, I personally think this would be the way to go.....ThumbUp
skuuter any advice is welcome
i have a plan but its not chiseled in stone,, this part of a build on a project that you've never done before can be a hand full.. i don't mind changing things up a little to build a safer, slicker rig for sure. Most of this delay in the build was just because i have a look that couldn't done with out building trike much wider than i had in mind from the jump. But I've never built spacer for struts i was contemplating building upper a-arm's that would have caused a lot more work than this solution i think its sound (the strut spacers that is) we will see in time!!! any advice appreciated !!
magoo
hey dragonponicsGreat build I will fallow this one I have a 04 impala I wrecked and have been thinking of doing the same with it just didn't know where to start
Well there is a lot of red tape to go through but not to bad
ThumbUp,,,Glad to hear the wife is doing well ,,and good work on the build . I'm really looking forward to see how this turns out , keep us posted on progress .ThumbUp
well the seats are on the way ...metal didn't show up ...guess I get it when I get it..
magoo
hi skuuterLate Material Arrival used to drive us crazy when I built Race Cars....."I wanna' build it, and I wanna' build it now"......:laugh:....Good Luck on Your Metal Arrival.....ThumbUp
hi skuuter
waiting on material for frame, waiting on new belts, pulleys, a/c delete and more...
now this morning wife said" maybe you should put a/c on trike like stallion has"
....I said well lets worry about that after I finish the build...
we have been riding for 45 years or so together with out a/c...for 30 years or so I would not have a radio
guess the world is changing..... not sure I'll catch up!!
magoo
