Stallion Remote Battery Posts
Sep 21, 2012
193
6
Howard Lake
Jeff
I just installed some remote battery posts in my Stallion trunk in case the battery goes low so you don't have to remove the wheel for a jump start.. I ordered the posts from Jegs http://www.jegs.com/i/JEGS-Performance-Products/555/10315K/10002/-1 and bought red and black 4 guage battery cables 29 inches long with eye terminals on each end at the local auto parts store..Drilled the two 1 1/4 inch holes in the trunk using a hole saw and attached and routed cables to the battery...The terminal bolts on the battery were plenty long to attach the cables to.......The cost was less than $50 for the materials.......ThumbUp
I just installed some remote battery posts in my Stallion trunk in case the battery goes low so you don't have to remove the wheel for a jump start.. I ordered the posts from Jegs JEGS Performance Products 10315K JEGS Remote Battery Jumper Terminals and bought red and black 4 guage battery cables 29 inches long with eye terminals on each end at the local auto parts store..Drilled the two 1 1/4 inch holes in the trunk using a hole saw and attached and routed cables to the battery...The terminal bolts on the battery were plenty long to attach the cables to.......The cost was less than $50 for the materials.......ThumbUp
Nice job and installation... After I replaced my '09 Stallions OEM battery with an Optima (yellow top), I opted to install a gauge to monitor my battery rather than to install the remote battery posts. Here's a link to the gauge I installed
BB-SBM12-PS Battery Bug Battery Monitor :: Argus Analyzers Paid about $40 for the gauge, if I recall through Wingstuff. So far, I'm very pleased with its performance. ThumbUp
Daydreamer
I've have had them on my Stallion since new and they also serve to help someone else needing a jump start !!! I know of several Stallion owners that have installed the cables and they are glad the did.
Tomg
I like the battery monitor thingy. I was not aware of that kind of device.
I believe in a pinch I could get a jumper cable through the wheel for a jump. The positive lead to the battery can be seen through the wheel and the ground could be connected somewhere else. My 2 cents.
yes you can or from under but its a REAL PAIN been there done that
In most cases, you won't have a dead battery on a good day or inside!! Probably in a muddy lot in a rain storm !!! Now you can try not to put electrical arcs on your rim in the mudd. But who knows, you might just get lucky.
Tomg
I think the Battery Bug idea is GREAT too....I am also going to install it ...Thanks for all the input and ideas everyone!!! :wave4:
Well the parts arrived and sat on the workbench until today ...... left the map light on last week. Installed the parts - quick charge and good to go. An excellent mod! pepper
I may be way out in left field on this one folks (doubt it), but wouldn't the factory-installed LED voltmeter on every Stallion perform the same function as an aftermarket "battery bug"?
If the meter isn't reading approximately 12.0 volts with engine off OR about 2 volts higher with engine running / charging system in operation then something's definitely amiss with the electrical system.
Welcome Smoke, from Rockford, IL. Do you have a Stallion? Good info to be had here. We are glad you are here.
The answer to your question is NO. That's why I installed one. Watch the video. The Battery Bug - YouTube . It will explain why they are different and why it's important to know the "state" of your battery over time.
Daydreamer
Cline
