Stallion Headlight mountings
Sep 19, 2017
133
17
Clinton Township, MI
Greg
I have been having a problem with the mounting for the headlight assembly. There are 3 posts with ball joints that the headlight assembly is mounted with. The ball joint on the top mounting post keeps popping out and this last time the assembly swiveled backwards when I was driving and it broke the back of the LED off and tore out part of the wiring harness. Now I not only need to replace the led headlight but also the harness. Can anyone tell me what I have to do to keep the upper mount in place? Lastly does anyone have the phone number to Thoroughbred motorsports in TX.?
More than likely the tabs that hold it in are worn or broke. I'm afraid your going to have to replace the whole assembly that is if TBMS has any left.
Haven't been active here much.. Been a CRAZY "busy season" so far...
I do believe this is the gentleman that called us yesterday & based on his description it's his headlight adjuster that is coming apart. Sounds like the locking part of the adjuster is staying in the hood but the other end of it is "coming loose".
Tflan
