Stallion fuel pump
May 23, 2020
1
Bay St Louis
Has anyone replaced the fuel pump on their Stallion? I need some pointers on how to do so. It started, ran for 5 seconds died and that's it. Blows the 30amp fuse for the fuel pump as soon as you turn the key. Need any and all help I can get. Thanks.
Bama boy
steve welcome. it should not be to bad if you can get it out. its on the left side of the tank in side mounting plate is on top. i have not tried to remove it but if it will come out though the opening you will be golden. if not then it could require tank removal which would be a big job. maybe richard the tech from tbms/motor trike can see this and advise.
Good morning
I was wondering if you got your fuel pump replaced did it come out without any modifications what model did you replace it with
Thank You
Dragon
I'm posting in case anyone is wondering about the answer to removing the fuel pump. You can expose the fuel pump by removing the rear seat back rest. You can test the electrical of the pump. However it is not removable at least on the 2009 model because the fiber glass body covers part of the pump. The only way I am aware of to remove the fuel pump is to remove the body.
3WHEELR
