So I'm tooling down the highway Tuesday. The overhead sign reads "AIR QUALITY ALERT AVOID IDLING." Suddenly four lanes of traffic come to a halt.
I know, RIGHT?
Anyhow, it's 1st gear, 2nd gear, stop, 1st gear, stop..........
20 minutes worth.
Down shifting again from second when the toe shifter goes all the way down to the floorboard and I am stuck in neutral.
I am able to coast between two cars to my left (barely avoiding getting pasted) and onto the median, up against the concrete barrier.
The forward pawl on the shaft from the shifter is loose and the splines are not engaging.
Okay, I pull out my Snap-on multi tool (with a great selection of allen and torx bits BTW) and try to wedge it between the frame and the pinch bolt. Doesn't quite fit. I get maybe 45 degrees of turn. Not enough to turn and reinsert the tool. Not quite enough pinch to bite the splines.
Traffic is now back up to speed. Like 3 feet from me.
I sorta get the tool in there on a bad angle and get enough bite that I figure I may be able to run gears if I play gentle footsie with the shifter.
This all takes like 30 minutes and 300 burns on my knuckles.
Start bike. Clunk. Okay, pick my spot and tear across 4 lanes to get to the exit to my right, get back on the highway and head home.
Take it all apart. Splines are all looking good, bolt is pristine. Put it back together and torque the $hit out of the bolt and all is good.
It must have been rocky for some time, I suppose, but I didn't feel it through my clunky boot.
You'd think that after spending all those years on Urals I'd be better at checking fasteners.
BUT, I got 3 years maintenance as part of the deal when I bought the bike so I assumed that the "check all fasteners" phrase in the work order meant check all fasteners.
Live and learn. I have a ratchet set in the trunk now. Glad I didn't get pasted..........
I know, RIGHT?
20 minutes worth.
