What’s the mounting difference in bagger slipons and trike slipons?
Baggers are easy to see and remove from the rear mounts, trikes are not as forgiving, they mount under the body and the bolts are in a not very user friendly spot, take a look at yours, you will see in a minute
Isn't there also a difference in inlet size?
Vance and Hines makes a set of slip-ons specifically for the trikes and they are made for left and right. the mounting brackets are on the side of the mufflers. there is a bracket that mounts to the Harley mounts and the mufflers mount to it. They have a smaller opening (about a 3 inch oval) for the exhaust that is offset giving a couple more inches of ground clearance.
