My 2016 Tri-Glide quit letting me shift gears. Just had a shift lever dangling uselessly on the side of my new Trike of just less than 10,000 miles.
I'm glad my wife and I were not still hundreds of miles away from the house on vacation. As it were, we were around 10 miles away and were able to ride home in first gear.
Once home I was able to determine that the back plate with the linkage attached was not moving but the shaft attached to the toe and heel levers was.
Long story short, after taking the whole assembly apart I found worn splines on the linkage plate end. The assembly could not be tightened to make it work. It's toast.
I live more than 100 miles away from my Harley dealer so they won't be able to fix it for me under warranty. I think they will give me the parts but I'm not sure.
Anyway, am I the only one that has rounded off the splines on the shifter shaft with only 10,000 miles? Any one else have to replace the shaft and linkage back plate on their Tri-Glide?
Thanks,
Brian
Thanks,
Brian
