Running lights install
I am looking at the DK driving lights to mount on my engine guard or at the footrests. Can someone either tell me how to wire them in with the low beams to stay on all the time or where the directions may be posted.
i understand that the Freewheeler has a wiring harness that would make it an easy install but I don't know wher it is located or where/how to make the connection.
any help would be appreciated.
Email us at Support@DKCustomProducts.com or you can PM me your email address. We will email you a PDF of the step-by-step directions.
Short answer to your questions is that there are wires going into your headlight bucket, that is probably the best place to connect the Stealth LED Driving Lights, via the included Posi-Tap connectors. No cutting, splicing or soldering needed.
Wish I'd seen this earlier! Yes, if you check out the wiring close you'll see a good place to tap in on the left side of the steering head. I used one tap for both hot wires, and another for both ground wires. Love those little taps, sure wish they sold them in stores!!
dyno56ca
