I HAVE DEVELOPED A ROUGH FEEL ON THE FRONT END OF MY STALLION WHEN I ROLL OVER A SMALL CRACK IN THE ROADS THAT I HAVEN'T FELT BEFORE. I CHECK OUT UNDER THE HOOD AND THE ONLY THING I SEE THAT MAY BE THE PROBLEM IS THAT THE BOTTOM PIECE OF THE "TREE" IS SITTING ON THE TOP OF THE SHOCK BRACKETS....MY QUESTION TO YOU GUYS IS " DOSE YOUR BOTTOM ALUMIUM STERRING PIECE SITTING ON TOP OF THE SHOCK BRACKET? WITH NO SPACE IN BETWEEN THE TWO PIECES?
ALSO I HAVE NOTICED THAT THE PAINTED FORK THAT GOES THRU THE BOTTOM TREE, THERE IS 1/4"-1/2" OF THE PAINT MISSING LIKE THE FORKS HAVE PUSHED UP FROM THE FACTORY INSTALL, WHICE ALLOWS THE BOTTOM ALUMIUM PIECE TO REST ON THE SHOCK BRACKET.....
ODDOMAN
# 667
EFFINGHAM, SC: Bug2:
ODDOMAN
# 667
