Roadsmith Recommended Tire Preasure.
Apr 12, 2018
9
2
bay city,mi usa
When I picked my Harley from having it converted, the dealer gave me a sticker with the recommended tire pressure it on it, 41psi front, left rear 31psi, right rear 34psi. Is anybody running these settings be sides me? I see a lot of different recommended settings.
Had mine converted at the factory and they recommended 41 front and 28 to 30psi in both rear tires.
Some one, some where, back in time, posted 41psi in the front for trikes and it became the "law". Well. that gave me a very harsh front end on my Wing/Hannigan. Ended up using 36 to 38 psi for a much smoother ride.
This is a personal opinion on the rears:
Only because the rear is offset to the right on a Hannigan, which os to align the rear w/ the Wings drive shaft out put, is there a difference in my left to right side tire pressures. After many tests, including running back and forth over a wet drive way at different pressures to get a full, flat tread pattern on the wet drive, I arrived at 22psi in the left and 24psi in the right.
Bullet Proof
