I have a '2000 Valkyrie Lehman Predator with drum brakes which I have been reliably advised cannot be converted to disc brakes.
I love the trike. It only has 25,000 miles of which I have put on 18,000 miles during the two years I've owned it. I've got the trike almost rigged out the way I want it.
The only problem is the rear drum brakes when wet. The brakes are dangerous - very dangerous in heavy rain or after riding through standing water.
Returning home from a week long trip recently, I ran into heavy rain about ten miles from home. I tapped the brakes lightly to check them and the road conditions and the rear immediately began locking up and skidding from side to side. I then slowed as much as was safe under freeway conditions by gently downshifting and turning onto lesser travelled streets asap. Even then at slow speeds the lightest touch on the pedal would lock one or the other rear wheel. When I was within 1,000 feet from home, a car pulled out in front of me and I had to jump a curb and stop on grass to avoid a crash.
I previously knew I had a problem after riding through standing water and would simply ride the brake long enough to dry them out. Riding on wet highways during light rains are not a problem beyond the normal somewhat slippery condition of the road surface.
I had never before rode the trike in a really heavy rain. The skidding was not from a wet highway. It most definitely was due to water in the brake drum
The problem is so serious to me that I am considering selling a trike I dearly love.
The he brakes are self-adjusting and the adjustment mechanisms are in proper order; the shoes are at least 75%; the drum surfaces are smooth and he tires are new with less than 5000 miles. The tread design is a rain tire design.
Do do those of you with drum brakes have such a serious problem as I am experiencing?
Would it be possible / practical to purchase a later model Lehman rear axle component with disc brakes and install it on my trike?
Would "drilling" the brake drums solve or diminish the problem?
I have some suspicion that the self-adjusting feature is to blame. Can it be removed if it would help?
Any comments or suggestions would be appreciated.
Dan
Dan
