I was reading about a problem with brakes failing on Harley's with antilock brakes, And that the NHTSA is investigating... Harley says that because people aren't changing the brake fluid every two years like recommended....I know my 11 Tri-Glide does not have antilock brakes but because i never bothered to change my fluid since i bought the Tri-Glide' I figured maybe i better look at it..So my son came over and we bled/ drained the just the rear brakes... If i didn't see it myself i wouldn't believe it, The fluid came out looking like old engine oil, And i had to use Q tips to clean out the reservoir which had a lot of black crud on the bottom... The front look normal, But i will change them out next week when i get new pads...
I can understand moisture getting in... But then the brakes would of felt spongy.. They were normal..
I have no idea where the black curd came from, But i could see how that might affect the antilock system.. :Shrug:
