Puzzling issue with rear lights
Mar 18, 2019
13
13
West Grove, PA, USA
Having a lighting issue I haven’t been able to solve. Tail lights, running lights, brake lights and hazards all work properly. However, when I turn on either of the signals they just get bright and do not flash. I’ve practically disassembled it looking for a bad ground. I also replaced the flasher unit. Any wiring wizards around here?
1999 Tour Glide with Electra Glide Sport front end. Torbleau trike kit.
You are correct Jack and if memory serves me correctly its zip tied to the right fork tube behind the fairing.
That is also what I remember. Had to replace one many years ago. Rectangular black box on right down tube . turn bars all way left & you should be able to see it. Unless someone moved it.
Gyl
