Bob25thTA
20+ Posts
This is shop diagnosis.
Customer States: DIAG SOFT FRONT BRAKE LEVER. FRONT BRAKE LEVER HAS NO PRESSURE. CONCERN STARTED 2 WEEKS AGO AND HAS GOTTEN PROGRESSIVELY WORSE. NO LEVER HAS NO PRESSURE AT ALL. CUSTOMER HAS NOT SEEN ANY SIGN OF FLUID LEAKS
TECH SERVICES REQUESTS THAT WE DO ABS SERVICE ONLY TO SEE IF THAT WILL FREE UP VALVE IN ABSMODULEREF# 4882963ABS SERVICE FAILED TO CORRECT PROBLEMAUTHORIZEATION TO REPLACE AND EXPEDITE ABS MODULE, A#326238
ABS Module was replaced and problem returned. Almost sounds like master cylinder bypassing. If I hit foot brake first the ABS "pumps" up the system and front brake works. If I press both at same time hand lever depresses all the way to the grip. Anyone else had an issue like this?
