removing front tire
I have a 2014 RS wing and need to remove front tire.How is everyone jacking the front end up? Remove bottom engine shield and jack there somewhere?
I use a small floor jack under the left crash bar and raise it until I can get a jack stand under the right crash bar. Then I slide another jack stand next to the floor jack and lower the jack with the left crash bar resting on the jack stand.
This is a very solid setup.
I'm not a fan of lifting under the engine. It wasn't designed for that.
I've lifted my front bike (TRIKE) under the engine for years....never any problems
Ronnie
2/2/24
I always used a car ramp drive trike upon slide jack under motor I do use a one by six jack it up then pull the ramp out been doing it for 10 years.:pepper:
Jack it up under engine (maybe if this will make you feel better/cut a 3 x3 inch piece of plywood) and put under engine then jack it up so the wood takes all the pressure... just a suggestion!!
Ronnie
2/9/24
wingbuck
