Passenger Running Board problem
Jun 3, 2011
1,488
438
tx
I took my wife to our local dealer today,for her to see and sit on a FW. Like a lot of women,she has long legs and with her feet on the passenger floor boards,her knees are higher than her hips. That's not going to work for anything but a short trip so has anyone come up with a way to allow more adjustability on the passenger boards? Our former Boss Hoss trike had fully adjustable driver floorboards and I might have to design something similar for the FW,if nothing else is available.
according to my owners manual the passenger floorboard has three adjustment positions. If the lowest setting does not work, hopefully there will be some method of further adjustment available soon. I have not researched it but if harley does not have something the after market might..
Wow, you learn something new all the time.....
I never knew the stock rear boards adjusted, I have to look into that.
Thanks,
Springman
The OEM passenger boards are adjustable. There are three positions and I think mine were in the top position. I lowered them to the lowest position but had to ream out the hole in the floorboard bracket slightly to get the bolt in on both sides.
Sunman
Sunman
Can you give us an estimate as to how much lower your passenger boards are now,compared to the top position? I was looking at a FW's rear boards today and wasn't sure they can be lowered very much. If I have to,I'll do a limited run of new running board brackets,cnc machined.
Only 1-3/4" adjustment.
Sunman
Harley also sells adjustable pass floorboard mounts ... you can mount them on the lowest spot, about 1.5" lower and then you can adjust lower ... I forget how much ... also you can move them forward a little
#50768-07A Part number for the ones I have ... doesn't say fits trike ... but they do ... same mount.
Kinda Pricy ... but good looking billet.
Thanks,
Springman
Check in the owner's manual. There are 2 bolts in the bracket. You remove the top bolt, only loosen the bottom bolt and slide the bracket up or down so that the top bolt hole in the bracket lines up with one of the three bolt holes in the frame depending on what level you want the floorboard at. Tighten both bolts and you are good to go.
Sunman
Thanks for that info,Fuzzy. I'll check them out.
So much for building the sexiest Hannigan trike out there (next to mine) ;)...
Sorry,my friend. I guess you and JT will just have to enjoy being the Top Dogs.
Sherry and I really like the FW and customizing ours is gonna be a blast.
Eddienorman
