Oil Change using a Flo and Go Vacuum Oil Change Kit
Well Fuzzy, you're a party pooper! :laugh:
I had not thought of that...was so stoked about easier oil/primary/trans changes.
But you make a VERY GOOD point about inspecting the magnet.
My Flo-n-Go was delivered today, and is sitting in my home office...I might use it every other oil change, as you suggest, but I don't think I will on the primary/trans. I do like to see what is on the magnet.
....OR...I may still use it, and when it is "dry" pull the plug then and look at/clean the magnet. We'll see.
I've Never seen sludge in a drain for decades...not too concerned about that.
A big Thank You for the heads up! :)
If you use synthetic, you shouldn't have to worry about sludge. My trike only had conventional oil the first 1k miles and synthetic after that so I don't think sludge is an issue. Plus, the suction is pretty good. As long as your oil is hot, you are going to suck out most of the oil that is in the pan. The longer I use this device, the better I will get at using it.
Tom Wallen
