About to get first 3,000 miles on new 2019 CSC Viper kit on my 2010 GL1800 Comfort. Since nearest dealer is 360 miles away, I need opinions on a few questions about first differential/rear oil change suggested for 3,000 miles....
I see that the only preferred jacking point for the rear end of the trike is on a plate just under the differential unit..which is also the location of the main drain bolt..Not really crazy about using a jack, so
I was wondering if I decided to use drive on ramps ... how many inches should I elevate with ramps?....Book says the normal ground clearance is 4 inches...so is another 4 inches going to be enough or maybe more ? Not a slim boy of 70+ years...needs some room and time to move on my back any more....
Sure would appreciate Goldwinger/CSC expertise and suggestions as to the easiest and safest way to do this on my garage floor....Thanks
Shaker
Shaker
