Need help!
Mar 30, 2010
16
Salinas, CA
Does anyone know where I could get a converter for my CSC trike? I have the six wire male plug from the factory ($29 please) but i need to find a six wire converter that turns intto a flat four connection to the trailer. Any ideas?
I tried that to use a four wire plug you have to create a short between 2 different circuits to use it. the Goldwing has 2 light circuits. i installed extra lights on my trailer and used the 6 pin connector. I found when you cross these circuits things don't work. The light circuit contains the back up lights and tail lights. the turn signal lights are on a completely different circuit. be careful. look at your wiring diagram in your manual
I have separate turn sig. in the Wing but combo on the trailer , use a converter from Wall Mart to covert it. $19.00
Re:Thanks
OK gang, here is what I did. I found a converter I had that was a 5 wire square throught the converter to a 4 pin flat. I cut off the 5 pin plug and installed the other half of the connection I got from CSC ($29 please). There was a black wire left over but I think it was for a 12v accessory. Hooked up the trailer turned on the ignition and VIOLA! everything worked as planned. Thanks to all for your help and advice.
baja
MelT
